1 (изменено: Mechatronica, 2017-01-03 00:03:51)
Тема: Axle load sensor Eurosens Difference 02 (Leaf spring suspension)
Eurosens Difference 02 applies to vehicles with leaf spring suspension. Can be installed on two-axle or three-axle vehicle, installation will be simple with an installation kit.
Eurosens Difference 02 in fact is resistive position sensor and is designed to provide information on the distance between the body and the axis of the vehicle. Measured value is proportional to axle load of vehicle.
Difference 02
Rated supply voltage Us = 24 V.  Output sensor voltage at the control points depending on the lever angle specified in Table 1.
Lever angle, degrees                         Output voltage, V
0                                                              1,54
10                                                            1,78
20                                                            2,02
30                                                            2,26
40                                                            2,50
50                                                            2,74
60                                                            2,98
70                                                            3,22
80                                                            3,46
leaf spring suspension, axle load sensor
It is important to observe when installing the sensor permissible angles of its lever movement.
2 (изменено: Mechatronica, 2017-01-03 00:04:11)
Re: Axle load sensor Eurosens Difference 02 (Leaf spring suspension)
Installation of Difference 02:
1. Measuring distance between frame and axle  at unloaded vehicle
2.  Measuring distance between frame and axle at fully loaded vehicle, calculating max suspension travel ∆
3. Choose a mounting places, determine level and arms (from service kit) length
After installing and connecting Difference 02 you have to perform a calibration in which you are mapping the output voltage of sensor with axle load.
axle load sensor Difference 02
Set length of lever L и height of rod H to get maximum lever angle travel during suspension deflection
Length of lever :
L = 0,7  * ∆ suspension travel
Then set height of rod to get at unloaded vehicle minimum voltage from sensor (1,38 V)
Eurosens Difference 02 installation
Installing Difference 02 on vehicle with double rear axles.
Position sensor for movement on the axles can be used the same fastening elements (plates and flanges). The only principal feature of mounting on such a vehicle is that the sensor rod is not fixed directly on the suspension elements but to intermediate rod.  Figures below, illustrates this.
examples:
axle load sensor, installation
Axle load sensor, calibration
calibration table
Calibration of Eurosens Difference:
Calibration by weighing of single axle  :   For axle load control
Calibration by weighing of vehicle  :   For cargo weight monitoring
Do you have to manually install the videos?
7 (изменено: Mechatronica, 2016-06-18 17:48:25)
No, we don't have video yet.
only this presentation
http://mechatronics.by/en/products/load … erence-02/
oh.thank ad
9
some new photos
Eurosens Difference 02 axle load sensor
Eurosens Difference 02 датчик нагрузки на ось
