		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; Axle load sensor Eurosens Difference 02 (Leaf spring suspension)]]></title>
		<link>https://forum.mechatronics.by/topic54-axle-load-sensor-eurosens-difference-02-leaf-spring-suspension.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic54.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Axle load sensor Eurosens Difference 02 (Leaf spring suspension)».]]></description>
		<lastBuildDate>Thu, 19 Jan 2017 11:34:17 +0000</lastBuildDate>
			<title><![CDATA[Re: Axle load sensor Eurosens Difference 02 (Leaf spring suspension)]]></title>
			<link>https://forum.mechatronics.by/post441.html#p441</link>
			<description><![CDATA[<p>some new photos</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/IMG_20170105_134327_7637315718.jpg" alt="Eurosens Difference 02 axle load sensor" /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/IMG_20170105_134343_4308592299.jpg" alt="Eurosens Difference 02 axle load sensor" /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/IMG_20170107_094049_4737129355.jpg" alt="Eurosens Difference 02 axle load sensor" /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/IMG_20170110_095227_2533895247.jpg" alt="Eurosens Difference 02 axle load sensor" /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/IMG_20170110_120923_7479893276.jpg" alt="Eurosens Difference 02 датчик нагрузки на ось" /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/IMG_20170110_143746_9948962479.jpg" alt="Eurosens Difference 02 датчик нагрузки на ось" /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/IMG_20170110_143806_9710788386.jpg" alt="Eurosens Difference 02 датчик нагрузки на ось" /></span></p>]]></description>
			<pubDate>Thu, 19 Jan 2017 11:34:17 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post441.html#p441</guid>
			<link>https://forum.mechatronics.by/post374.html#p374</link>
			<description><![CDATA[<p>oh.thank ad</p>]]></description>
			<author><![CDATA[null@example.com (sihieu5692)]]></author>
			<pubDate>Mon, 20 Jun 2016 01:20:52 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post374.html#p374</guid>
			<link>https://forum.mechatronics.by/post373.html#p373</link>
			<description><![CDATA[<p>No, we don&#039;t have video yet.<br />only this presentation<br /><a href="http://mechatronics.by/en/products/load-control/eurosens-difference-02/">http://mechatronics.by/en/products/load … erence-02/</a></p>]]></description>
			<pubDate>Sat, 18 Jun 2016 13:34:16 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post373.html#p373</guid>
			<link>https://forum.mechatronics.by/post372.html#p372</link>
			<description><![CDATA[<p>Do you have to manually install the videos?</p>]]></description>
			<pubDate>Mon, 13 Jun 2016 04:18:27 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post372.html#p372</guid>
			<link>https://forum.mechatronics.by/post242.html#p242</link>
			<description><![CDATA[<p><strong>Calibration of Eurosens Difference:</strong></p><p>Calibration by weighing of single axle&nbsp; :&nbsp; &nbsp;For axle load control</p><p>Calibration by weighing of vehicle&nbsp; :&nbsp; &nbsp;For cargo weight monitoring</p>]]></description>
			<pubDate>Sat, 07 Nov 2015 21:13:50 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post242.html#p242</guid>
			<link>https://forum.mechatronics.by/post241.html#p241</link>
			<description><![CDATA[<p><strong>Axle load sensor, calibration</strong></p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_calibration_table_3120767944.png" alt="calibration table" /></span></p>]]></description>
			<pubDate>Sat, 07 Nov 2015 21:09:10 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post241.html#p241</guid>
			<link>https://forum.mechatronics.by/post240.html#p240</link>
			<description><![CDATA[<p>examples:</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_nagruzka_na_osy,_ustanovka_datchika_8580746711.png" alt="axle load sensor, installation" /></span></p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_nagruzka_na_osy,_ustanovka_datchika_3471073075.png" alt="axle load sensor, installation" /></span></p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_nagruzka_na_osy,_ustanovka_datchika_143251027.png" alt="axle load sensor, installation" /></span></p>]]></description>
			<pubDate>Sat, 07 Nov 2015 21:07:03 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post240.html#p240</guid>
			<link>https://forum.mechatronics.by/post239.html#p239</link>
			<description><![CDATA[<p>Installation of Difference 02:</p><p>1. Measuring distance between frame and axle&nbsp; at unloaded vehicle<br />2.&nbsp; Measuring distance between frame and axle at fully loaded vehicle, calculating max suspension travel ∆<br />3. Choose a mounting places, determine level and arms (from service kit) length</p><br /><br /><p>After installing and connecting Difference 02 you have to perform a calibration in which you are mapping the output voltage of sensor with axle load. </p><br /><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/axle_load_sensor_Difference_02_71970592.png" alt="axle load sensor Difference 02" /></span></p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/axle_load_sensor_Difference_02_574557185.png" alt="axle load sensor Difference 02" /></span></p><br /><p>Set length of lever L и height of rod H to get maximum lever angle travel during suspension deflection</p><p>Length of lever :<br /><strong>L = 0,7&nbsp; * ∆ suspension travel</strong><br />Then set height of rod to get at unloaded vehicle minimum voltage from sensor (1,38 V)</p><br /><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_Eurosens_Difference_02_installation_2375028971.png" alt="Eurosens Difference 02 installation" /></span></p><br /><p><strong>Installing Difference 02 on vehicle with double rear axles.</strong></p><p>Position sensor for movement on the axles can be used the same fastening elements (plates and flanges). The only principal feature of mounting on such a vehicle is that the sensor rod is not fixed directly on the suspension elements but to intermediate rod.&nbsp; Figures below, illustrates this. </p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_Eurosens_Difference_02_installation__2708718013.png" alt="Eurosens Difference 02 installation " /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_Eurosens_Difference_02_installation__4103816496.png" alt="Eurosens Difference 02 installation " /></span></p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_Eurosens_Difference_02_installation__8951142611.png" alt="Eurosens Difference 02 installation " /></span><br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_Eurosens_Difference_02_installation__4550710883.png" alt="Eurosens Difference 02 installation " /></span></p>]]></description>
			<pubDate>Sat, 07 Nov 2015 20:56:55 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post239.html#p239</guid>
			<title><![CDATA[Axle load sensor Eurosens Difference 02 (Leaf spring suspension)]]></title>
			<link>https://forum.mechatronics.by/post194.html#p194</link>
			<description><![CDATA[<p>Eurosens Difference 02 applies to vehicles with leaf spring suspension. Can be installed on two-axle or three-axle vehicle, installation will be simple with an installation kit.</p> <br /><p>Eurosens Difference 02 in fact is resistive position sensor and is designed to provide information on the distance between the body and the axis of the vehicle. Measured value is proportional to axle load of vehicle.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Difference_02_8866089326.jpg" alt="Difference 02" /></span></p><br /><p>Rated supply voltage Us = 24 V.&nbsp; Output sensor voltage at the control points depending on the lever angle specified in Table 1. </p><br /><p>Lever angle, degrees&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Output voltage, V<br />0&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 1,54<br />10&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 1,78<br />20&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 2,02<br />30&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 2,26<br />40&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 2,50<br />50&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 2,74<br />60&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 2,98<br />70&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 3,22<br />80&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 3,46</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/ustanovka_datchika_nagruzki_na_osy,_ressory_1068095788.png" alt="leaf spring suspension, axle load sensor" /></span></p><p>It is important to observe when installing the sensor permissible angles of its lever movement.</p>]]></description>
			<pubDate>Sun, 13 Sep 2015 21:20:23 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post194.html#p194</guid>
