1 (изменено: Mechatronica, 2016-07-08 23:19:33)
Тема: Eurosens Dizzi - noninvasive acoustic luquid level sensor
Ultrasonic level sensors Eurosens Dizzi  is used for non-contact (non-invasive) level measurement of acoustically
transparent liquids.
Measurement is done by external echolocation through the bottom of tank.
Not China! Own design of probe and  electronic processed unit.
Features
  • No tank modification required. All sensor components are placed outside the tank. It is very important when you measure aggressive, explosive, food liquids, as well as highpressurized liquids.
    You can measure level of any liquid, including liquefied gas.
    Smart self-diagnostic algorithm provides stable data without let or hindrance.
    Explosion-proof certified : 0ЕхiaIICT6Ga,[ExiaGa]IIC.
    Output interface : RS232, RS485 (LLS, MODBUS), frequency (500-1500 Hz), analog output (0-10V).
Details
Range of measurement, mm                       20 – 3000
Max. thickness of the tank wall, mm            0 – 50
Error, in static condition, mm                         0,1
Max temperature of tank surface, °C              100
Supply voltage, V                                          9 – 30
Reverse polarity protection                              Yes
Protection class (acoustic probe)                      IP 67
Re: Eurosens Dizzi - noninvasive acoustic luquid level sensor
Examples of data:
MAZ truck, ultrasonic level sensor (yellow chart) installed together with capacitive level sensor (green)
Eurosens Dizzi data
Eurosens Dizzi ultrasonic level sensor
Eurosens Dizzi, Eurosens Dominator
Fuel consumption monitoring at Opel Corsa
Eurosens Dizzi Opel
data from Eurosens Dizzi
(fuel chart - height of level in mm)
4 (изменено: Mechatronica, 2016-02-27 13:14:03)
How to connect Eurosens Dizzi here : https://forum.mechatronics.by/topic82-e … setup.html
Place of installation
Eurosens Dizzi installation
Searching for suitable place for installation:
Install eurosens Dizzi
install eurosens Dizzi 2
To find a suitable place and position you will use special service software. It displays currect signal level and quality of installation in %.
install eurosens Dizzi 3
Apply glue to the pre-processed with solvent probe surface
clue at Dizzi
Glue the probe to the installation place, in addition it will be fixed by metal tie
When gluing, do not forget to check the signal strength in the service software.
After fixing screw tightly the metal locking tie
Tank calibration you can made as usual.
Video of Oscilloscope software
Signal level indication
What other Eurosens Dizzi against the Eurosens Dominator AF ?
7 (изменено: Mechatronica, 2016-05-22 10:25:13)
sihieu5692 сказал:
Precision is same.
Capacitive sensor is cheaper, installation is different way but same difficulty.
We recommend to use Dizzi as second choice, when you can't install Eurosens Dominator for some reasons:
  • customer refuse to drill the tank
  • diesel fuel contains a big part of water and capacitive sensors don't work
  • you need to measure not fuel but agressive or edible liquids
  • you need to measure LNG
thank Admin
9
10
How much is the accuracy of the senson Eurosens Dizzi ?
11
sihieu5692 сказал:
Same with capacitive level sensors
12
Are you items for purchase?
13
Of course, see our contacts at website  http://mechatronics.by/en/mechatronics-contacts/
14
more information about installation you can see at this topic:
https://forum.mechatronics.by/topic105- … ation.html
