Тема: Eurosens Dizzi - noninvasive acoustic luquid level sensor
Ultrasonic level sensors Eurosens Dizzi is used for non-contact (non-invasive) level measurement of acoustically
transparent liquids.
Measurement is done by external echolocation through the bottom of tank.
Not China! Own design of probe and electronic processed unit.
Features
No tank modification required. All sensor components are placed outside the tank. It is very important when you measure aggressive, explosive, food liquids, as well as highpressurized liquids.
You can measure level of any liquid, including liquefied gas.
Smart self-diagnostic algorithm provides stable data without let or hindrance.
Explosion-proof certified : 0ЕхiaIICT6Ga,[ExiaGa]IIC.
Output interface : RS232, RS485 (LLS, MODBUS), frequency (500-1500 Hz), analog output (0-10V).
Details
Range of measurement, mm 20 – 3000
Max. thickness of the tank wall, mm 0 – 50
Error, in static condition, mm 0,1
Max temperature of tank surface, °C 100
Supply voltage, V 9 – 30
Reverse polarity protection Yes
Protection class (acoustic probe) IP 67
