1 (изменено: Mechatronica, 2020-03-31 10:40:32)
Тема: How to connect 2 fuel level sensors, Display RS to GPS tracker (RS485)
Devices to use:
Eurosens Display RS
using Eurosens Display CAN(RS) User configurator
Display info
Re: How to connect 2 fuel level sensors, Display RS to GPS tracker (RS485)
Display settings:
Display Config
Setting up the adder feature of display - calculate total volume from 2 tanks
Display Adder
4 (изменено: Mechatronica, 2020-03-31 10:23:35)
Settings of sensor №1
Sensor 1 Config
Sensor №1 should have calibration table of the tank programmed
Sensor 1 tank calibration
Sensor 1 current data
Sensor 1 Current state
Configuration of sensor №2
Sensor 2 Config
Sensor №2 also should have tank calibration table
Sensor 2 Taring
9
Actual data coming from sensor 2
Sensor 2 Current state
10
Settings of the GPS tracker. We use Smart-2435 GPS.
Adding 2 fuel level sensors to read
2435 protocol set rs485
11 (изменено: Mechatronica, 2020-03-31 10:36:10)
Fuel level sensor protocol settings
2435 LLS active
12
When all connected properly we will see instant fuel sensors data in GPS tracker configurator
2435 LLS telemetry check data
13
Display RS will show total value
Display total level
14
Display RS also will show tank1 and tank2 volumes:
Display tank 1
Display tank  2
