		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; How to connect 2 fuel level sensors, Display RS to GPS tracker (RS485)]]></title>
		<link>https://forum.mechatronics.by/topic175-how-to-connect-2-fuel-level-sensors-display-rs-to-gps-tracker-rs485.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic175.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «How to connect 2 fuel level sensors, Display RS to GPS tracker (RS485)».]]></description>
		<lastBuildDate>Tue, 31 Mar 2020 06:39:49 +0000</lastBuildDate>
			<title><![CDATA[Re: How to connect 2 fuel level sensors, Display RS to GPS tracker (RS485)]]></title>
			<link>https://forum.mechatronics.by/post760.html#p760</link>
			<description><![CDATA[<p>Display RS also will show tank1 and tank2 volumes:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Display_tank_1_5445406157.jpg" alt="Display tank 1" /></span></p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Display_tank__2_2465874669.jpg" alt="Display tank&nbsp; 2" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:39:49 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post760.html#p760</guid>
			<link>https://forum.mechatronics.by/post759.html#p759</link>
			<description><![CDATA[<p>Display RS will show total value</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Display_total_level_3866006247.jpg" alt="Display total level" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:38:49 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post759.html#p759</guid>
			<link>https://forum.mechatronics.by/post758.html#p758</link>
			<description><![CDATA[<p>When all connected properly we will see instant fuel sensors data in GPS tracker configurator</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/2435_LLS_telemetry_check_data_3375810412.jpg" alt="2435 LLS telemetry check data" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:37:10 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post758.html#p758</guid>
			<link>https://forum.mechatronics.by/post757.html#p757</link>
			<description><![CDATA[<p>Fuel level sensor protocol settings</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/2435_LLS_active_3452979954.jpg" alt="2435 LLS active" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:35:53 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post757.html#p757</guid>
			<link>https://forum.mechatronics.by/post756.html#p756</link>
			<description><![CDATA[<p>Settings of the GPS tracker. We use Smart-2435 GPS.</p><p>Adding 2 fuel level sensors to read</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/2435_protocol_set_rs485_3065776512.jpg" alt="2435 protocol set rs485" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:34:28 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post756.html#p756</guid>
			<link>https://forum.mechatronics.by/post755.html#p755</link>
			<description><![CDATA[<p>Actual data coming from sensor 2</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Sensor_2_Current_state_2911921702.jpg" alt="Sensor 2 Current state" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:32:40 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post755.html#p755</guid>
			<link>https://forum.mechatronics.by/post754.html#p754</link>
			<description><![CDATA[<p>Sensor №2 also should have tank calibration table</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Sensor_2_Taring_3869532588.jpg" alt="Sensor 2 Taring" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:31:31 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post754.html#p754</guid>
			<link>https://forum.mechatronics.by/post753.html#p753</link>
			<description><![CDATA[<p>Configuration of sensor №2</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Sensor_2_Config_2816445431.jpg" alt="Sensor 2 Config" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:30:29 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post753.html#p753</guid>
			<link>https://forum.mechatronics.by/post752.html#p752</link>
			<description><![CDATA[<p>Sensor 1 current data</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Sensor_1_Current_state_1152377570.jpg" alt="Sensor 1 Current state" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:26:33 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post752.html#p752</guid>
			<link>https://forum.mechatronics.by/post751.html#p751</link>
			<description><![CDATA[<p>Sensor №1 should have calibration table of the tank programmed</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Sensor_1_tank_calibration_9664372634.jpg" alt="Sensor 1 tank calibration" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:24:30 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post751.html#p751</guid>
			<link>https://forum.mechatronics.by/post750.html#p750</link>
			<description><![CDATA[<p>Settings of sensor №1<br /><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Sensor_1_Config_7231238796.jpg" alt="Sensor 1 Config" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:22:51 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post750.html#p750</guid>
			<link>https://forum.mechatronics.by/post749.html#p749</link>
			<description><![CDATA[<p>Setting up the adder feature of display - calculate total volume from 2 tanks</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Display_Adder_1171672386.jpg" alt="Display Adder" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:19:56 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post749.html#p749</guid>
			<link>https://forum.mechatronics.by/post748.html#p748</link>
			<description><![CDATA[<p>Display settings:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Display_Config_3844325272.jpg" alt="Display Config" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:18:28 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post748.html#p748</guid>
			<title><![CDATA[How to connect 2 fuel level sensors, Display RS to GPS tracker (RS485)]]></title>
			<link>https://forum.mechatronics.by/post747.html#p747</link>
			<description><![CDATA[<p>Devices to use:</p><p>Eurosens Display RS<br />using Eurosens Display CAN(RS) User configurator</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Display_info_7585169575.jpg" alt="Display info" /></span></p>]]></description>
			<pubDate>Tue, 31 Mar 2020 06:13:42 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post747.html#p747</guid>
