Тема: Flow meter installations
Delta PN500 flow meter was installed and works on 220-tonn Belaz dump truck
Delta Belaz
Delta Belaz 2
Re: Flow meter installations
Some new installations
Terex-with-DeltaDelta-on-Terex-Engine
China truck deltaDelta flow meter truck
China truckEurosens Delta
IMG_2225 Delta locomotive
Eurosens Delta locomotive fuel meter Eurosens Delta locomotive
Installing Eurosens Direct on locomotive
Eurosens Direct train
Installation Eurosens Direct on locomotive
IMG_2209
IMG_2210
IMG_2212
IMG_2214
4 (изменено: Mechatronica, 2015-03-03 00:57:55)
Thanks to Pavel from Lithuania
image-8442a8e6cb83e4fc476b8e8c14cca8f38e47beb1d070d2a55f32c82ab78622b0-Vimage-3269790c5f58969556989a12fa4de2c67908223604fed3fe3dde0039b4d5508f-V
image-ae5a4b3ed798b6e5e0993b67628283ac6aee9e156aa7b52b7bbe2c8e674e0017-Vimage-f2c3400322d90fed3449ea7b77acfe23f8d5e4773515aa6c6db72d5bf78a9b09-Vimage-f908db147c131ae0129538e6e531aee4fccd29005b092fe0eef41783bcb3549b-V
5 (изменено: Mechatronica, 2015-03-14 20:29:11)
Again, new photos from Lithuania with Eurosens Direct P100
20150312_17495320150312_174208
20150312_17420820150312_174307
20150312_17431420150312_174335
20150312_17434520150312_180702
20150312_18071520150312_180725
20150312_18073420150312_202912
20150312_20292420150312_202940
20150312_21132820150312_211335
6 (изменено: Mechatronica, 2015-04-27 00:28:27)
Caterpillar 843H + Eurosens Delta
Caterpillar 843H + Eurosens DeltaCaterpillar 843H + Eurosens Delta
Volvo dump truck  + Delta PN I
IMG_20150326_064319IMG_20150326_073907
Bus with Cummins engine
IMG_20150330_045649IMG_20150330_064852IMG_20150330_064904IMG_20150330_065002IMG_20150330_065019IMG_20150330_065036
9 (изменено: Mechatronica, 2017-01-02 23:37:40)
Crawler with Eurosens Direct
IMG_2329IMG_2331
10
UAZ jeep with Andoria diesel and Eurosens Direct
IMG_2343IMG_2336
IMG_2337IMG_2338IMG_2339
11 (изменено: Mechatronica, 2015-04-26 12:44:31)
Grader with YAMZ238 diesel and Eurosens Direct PN250I
Eurosens Direct PN250I and YAMZ 238Eurosens Direct PN250I and YAMZ 238
Eurosens Direct PN250I and YAMZ238Direct PN250I and YAMZ238Direct PN250I and YAMZ238Direct PN250I and YAMZ238Direct PN250I and YAMZ238Direct PN250I and YAMZ238
12
K-700 powerful Russian tractor with Eurosens Direct
K-700 tractor and Eurosens DirectK-700 tractor and Eurosens Direct fuel meterK-700 and Eurosens Direct fuel flow meter
13
Kamaz truck with Cummins engine. Eurosens Delta differential flow meter is installed
Kamaz, Cummins, Eurosens Delta
Kamaz, Cummins, Eurosens DeltaKamaz, Cummins, Eurosens DeltaKamaz, Cummins, Eurosens DeltaKamaz, Cummins, Eurosens DeltaKamaz, Cummins, Eurosens DeltaKamaz, Cummins, Eurosens DeltaKamaz, Cummins, Eurosens DeltaKamaz, Cummins, Eurosens Delta
14 (изменено: Mechatronica, 2015-04-26 22:14:25)
Kamaz truck with Direct PN fuel flow meter
Kamaz and Eurosens DirectKamaz and Eurosens DirectKamaz and Eurosens DirectKamaz and Eurosens DirectKamaz and Eurosens DirectKamaz and Eurosens DirectKamaz and Direct fuel flow meterKamaz and Direct fuel flow meter
15 (изменено: Mechatronica, 2015-04-26 22:30:52)
Kamaz and Direct PN250I
Kamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IKamaz and Direct PN250IIMG_20150406_060957
16
MAZ small truck with MMZ 245 diesel and Eurosens Direct
MAZ truck and Eurosens Direct PNMAZ truck and Eurosens Direct PNMAZ truck and Eurosens Direct PNMAZ truck and Eurosens Direct fuel meterMAZ truck and Eurosens Direct fuel meter
17
Dressta with installed Eurosens Direct
Dressta and Eurosens Direct fuel meterDressta and Eurosens Direct fuel meterDressta and Eurosens Direct fuel meterDressta and Eurosens Direct fuel meterDressta and Eurosens Direct fuel meterDressta and Eurosens Direct fuel meterDressta and Eurosens Direct fuel meter
18
URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN
URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN URAL truck with YAMZ-238 diesel engine and Eurosens Direct PN IMG_20150327_065020IMG_20150404_084203IMG_20150404_055838
19 (изменено: Mechatronica, 2015-04-27 00:22:15)
Excavator CAT 385 with Eurosens Delta fuel flow meter
Excavator CAT 385 with Eurosens Delta fuel flow meterExcavator CAT 385 with Eurosens Delta fuel flow meter
Excavator CAT 385 with Eurosens Delta fuel flow meterExcavator CAT 385 with Eurosens Delta fuel flow meterExcavator CAT 385 with Eurosens Delta fuel flow meterExcavator CAT 385 with Eurosens Delta fuel flow meterExcavator CAT 385 with Eurosens Delta fuel flow meterExcavator CAT 385 with Eurosens Delta fuel flow meter
20
Eurosens Direct P100Eurosens Direct P100Eurosens Direct P100Eurosens Direct P100Eurosens Direct P100Eurosens Direct P100Eurosens Direct P100Eurosens Direct P100
21 (изменено: Mechatronica, 2015-11-15 15:23:41)
Eurosens Direct at grader DZ-180
Eurosens direct installationEurosens direct P100 installation
Eurosens direct P100 installationEurosens direct P100 installation
22
Eurosens Delta is working with Lowrance MFD via NMEA2000!
nmea2000_Eurosens Delta
NMEA2000_Eurosens Delta2
