In the Sensor field you can set the number of sensor, in the connection order to the receiver. This number is reflected in the RS485 data address. Number one means you’ll see this sensor data in LLS protocol of RS485 interface under first address.
Temp_offset parameter is permanent temperature offset of the data and can be used for the calibration of the temperature sensor.
We can change the source of temperature data by changing Temp_source setting. It is possible to choose one of three sources : temperature sensors are built-in in the humidity sensor, radiolink module and central processor module. By default humidity sensor is the main source of data but some sensors doesn’t have the humidity sensor option so you can choose one of the rest sources.
Update parameter defines how often sensor sends the data. More frequency of update leads to faster battery drain.
Receiver collects data from all available temperature sensors. To divide receivers/sensors into groups we can use the parameter RF network mask. Receiver with network mask №2 doesn’t read the sensors with network mask №1. To assign the sensor with the new network mask we only need to make its settings with the receiver with new network mask already assigned in settings.
