Device setup
Changing the settings is performed by sending the appropriate commands to the device.
There are several options available:
SMS
through the monitoring server (in Wialon: "Sending messages to the driver")
locally through the program via USB interface (DTM_logger.exe )
through a remote server WEB configurator (available to corporate clients)
The message structure for settings commands next: <device_password>*SETP*<list_of_arguments>
Default value for field <device_password> is 123456
Field of <list_of_arguments> contains the number and the value of one or more parameters that you can edit.
Each element from the list of changeable parameters has the following structure:
#<number_parametr>=<value>
< number_parametr > - the numeric index of the parameter
<value> - the new value of the parameter, can be simple or complex.
The list items are delimited: a sign of the end of one element is the beginning of the next (sign #).
When sending messages via SMS it is necessary that the length of the message does not exceed 160 characters, and in the message was present only letters of the Latin alphabet.
The following is a description of the formats to change each parameter.
Note: to understand the beginning and end of the last message enclosed in single quotes (‘).
No need to use quotation marks when sending messages to the device.
Parametr_number: 1 – Address & port for monitoring server
Command format:
‘#1=<server_address>,<server_port>’
Arguments:
<server_address> - string up to 32 characters. Contains the DNS name or IP address of the server.
<server_port> - a number from 1 to 65535. Not a mandatory parameter: in the absence of the need to change the server port setting can not convey.
Examples:
‘123456*SETP*#1=193.193.165.165,20897’ – set the IP address and port of the server
‘123456*SETP*#1=m2m.duotec.ru,20897’ – to set the DNS name and port of the server
‘123456*SETP*#1=example.org’ – only change the server address, server port is left unchanged
Parametr_number: 2 – APN settings GSM operator for SIM card #1 (Top slot)
Command format:
‘#2=<APN_string>,<APN_login>,<APN_password>’
Arguments:
<APN_settings> - string up to 32 characters. Contains the access point name
<APN_login> - string up to 32 characters. Contains the user name of the access point
<APN_password> - string up to 32 characters. Contains the password of the access point
Examples:
‘123456*SETP*#2=internet,gdata,gdata’ – to set the APN settings operator "MegaFon"
‘123456*SETP*#2=,,’ – to clear the APN settings
Parametr_number: 3– Device password
Command format:
‘#3=<new_device_password>’
Arguments:
<new_device_password> - string up to 8 characters. Contains the new password to access the device. An empty string means that access to the device will be made without a password
Examples:
‘123456*SETP*#3=13571’ – to set an access password 13571
‘123456*SETP*#3=’ – to disable password protection of the device
Parametr_number: 4 – The PIN code of the SIM card #1 (Top slot)
Command format:
‘#4=<pin_code>’
Arguments:
<pin_code> - string up to 8 characters. Contains the code that will be entered if the SIM card has a PIN code request.
ATTENTION! This command stores the PIN in the memory device and does NOT switch/change of PIN code on the SIM card. Therefore, if the SIM card is already enabled PIN, then the names in this parameter has a bad value will lock the card. An empty string means that the PIN is not set.
Examples:
‘123456*SETP*#4=2468’ – when you request a SIM card PIN code is entered 2468
‘123456*SETP*#4=’ – erase PIN
Parametr_number: 5 – Trajectory calculation
Command format:
‘#5=<distance>,<angle>,<speed>,<interval>’
Arguments:
<distance> - the number from 100 to 65535 or 0. If the distance between the last position sent to the server, and the current position exceeds the specified value, then the current position will be sent to the server. The unit of measure is the meter. Is not required: if there is no need of changing the distance parameter can not convey. A value of 0 disables the condition is sent to the server by distance.
<angle> - a number from 0 to 180. If the change of the angle between the course of the last position sent to the server, and the current rate exceeds the specified value, then the current position will be sent to the server. The unit of measure is degrees. Is not required: if there is no need of changing the angle parameter can not convey. A value of 0 disables the condition is sent to the server in the corner.
<speed> - the number 5 or 0 to 65535. If the change between the speed at the time the last position sent to the server, and the current speed exceeds the specified value, then the current position will be sent to the server. The unit is kilometer per hour. Not a mandatory parameter: in the absence of the need to change the speed setting can not convey. A value of 0 disables the condition is sent to the server by the change of speed.
<interval> - the number 5 or 0 to 65535. If the interval between the time of the last send the coordinates to the server and the current time exceeds the specified value, then the current position will be sent to the server. The unit of measurement is seconds. Not a mandatory parameter: in the absence of the need to change the sending interval setting can not convey. A value of 0 disables the condition is sent to the server at the interval.
Examples:
‘123456*SETP*#5=400,18,20,150’ – set all processing parameters of the trajectory
‘123456*SETP*#5=,,35,300’ - only change the speed and spacing, the distance and angle to remain unchanged
‘123456*SETP*#5=,15’ – only change the angle, the other parameters are left unchanged
‘123456*SETP*#5=,,0’ – disable the condition of sending messages by the change of speed
Parametr_number: 6 – Power saving mode
Command format:
‘#6=<mode>, <sleep_time>,<active_time>’
Arguments:
<mode> - number of mode:
0 – power saving mode turn off: device always active (work);
1 ¬– deep sleep: all nodes of the device are turned off except the accelerometer, the processor core is not active. Exit from deep sleep mode is possible by triggering the accelerometer and timer. Not a mandatory parameter: in the absence of the need to change the sleep mode setting can not convey.
<sleep_time> - a number from 0 to 65535. Specifies the time spent by the device in sleep mode in minutes if sleep mode is activated (see power saving Mode). If the parameter is 0, then exit from sleep mode is only possible by triggering the accelerometer. Not a mandatory parameter: in the absence of the need to change the sleep time setting can not convey.
<active_time>- a number from 0 to 65535. Specifies the time spent by the device in the active mode in minutes after cessation of exposure to the accelerometer, if the sleep mode is activated (see power saving mode). Once the impact on the accelerometer stops, at the expiration of this time the unit will go into sleep mode. Not a mandatory parameter: in the absence of the need to change the active time parameter can not convey.
Examples:
‘123456*SETP*#6=1,60,5’ – to enable sleep mode, set the time of exit from sleep 1 hour (the device may get out of bed earlier - triggered accelerometer), go into sleep mode after 5 minutes after cessation of exposure to an accelerometer.
‘123456*SETP*#6=1,0,10’ – to enable sleep mode, disable sleep mode on timer off sleep is only possible by triggering the accelerometer), go into sleep mode after 10 minutes after cessation of exposure to an accelerometer.
‘123456*SETP*#6=,,3’ – change the transition time to the sleep mode after the cessation of exposure to the accelerometer, the parameters ‘mode’ and ‘sleep_time’ to leave unchanged
‘123456*SETP*#6=0’ – to turn off power saving mode
Parametr_number: 7 – APN settings GSM operator for SIM card #2 (Bottom slot)
Command format:
‘#7=<APN_string>,<APN_login>,<APN_password>’
Arguments:
Examples:
‘123456*SETP*#7=internet,gdata,gdata’ – to set the APN settings operator "MegaFon"
‘123456*SETP*#7=,,’ – to clear the APN settings
Parametr_number: 8 – The PIN code of the SIM card #2 (Bottom slot)
Command format:
‘#8=<pin_code>’
Arguments:
Examples:
‘123456*SETP*#8=2468’ – when you request a SIM card PIN code is entered 2468
‘123456*SETP*#8=’ – erase PIN
Parametr_number: 9 – Discrete pins (inputs & outputs)
Command format:
‘#9=<mode_IN0>,<mode_IN1>,<mode_OUT>’
Arguments:
<mode_IN0> - a character indicating the mode IN0:
N – not use;
D – discrete (shorted to minus (GND) - active, otherwise inactive);
C – impuls (counting the number of pulses);
F – frequency (measuring the frequency of pulses);
G – control the "massa-GND" (closed in "a minus (GND)" - "massa (GND)" is enabled, otherwise disabled)
Not a mandatory parameter: in the absence of the need to change the operation mode IN0 parameter can not convey.
< mode _IN1> - a character indicating the mode IN1:
N – not use;
D – discrete (if the voltage is above 5.0 V - active or – inactive);
A – analog (measurement of voltage 0-32 V).
Not a mandatory parameter: in the absence of the need to change the operation mode IN1 parameter can not convey.
< mode _OUT> - a character indicating the mode IN5:
N – not use;
O - output (open drain 500 mA) with state saving in non-volatile memory.
Not a mandatory parameter: in the absence of the need to change the operation mode_OUT parameter can not convey.
Examples:
‘123456*SETP*#9=D,D,O’ – to set the operating mode IN0-IN1 – discrete, OUT – out
‘123456*SETP*#9=,A’ – IN1 – analogue, other modes of contact to remain unchanged.
‘123456*SETP*#9=F’ – change the mode IN0 frequency, modes other contacts to remain unchanged.
Parametr_number: 11 – Digital inputs (RS485)
Command format:
‘#11=<mode_RS485>’
Arguments:
<mode_RS485> - number that specifies the mode of the RS485 interface:
0 – not use;
5 – fuel level sensor (protocol LLS). up to 8 sensors inclusive; the sensors must have a network address from 1 to 8.
Not a mandatory parameter: in the absence of the need to change the mode of the RS485 interface option can not convey.
Examples:
‘123456*SETP*#11=5’ – enable fuel level sensor
‘123456*SETP*#11=0’ – disable the RS485 interface.
Parametr_number: 15 – Roaming
Command format:
‘#15=<SIM1>,<SIM2>’
Arguments:
<SIM1> - mode of operation in international roaming:
0 – the data roaming is prohibited, when returning to a home network, all data will be unloaded;
1 – the data roaming is allowed.
<SIM2> - mode of operation in international roaming:
Examples:
‘123456*SETP*#15=1,0’ – the data roaming is allowed for SIM card #1.
‘123456*SETP*#15=0,0’ – the data roaming is prohibited, when returning to a home network, all data will be unloaded.
RUSAVL.COM - AVL components from Russia
skype : rusavl.com
