Тема: How to connect Eurosens Display RS+Dominator RS+GPS tracker (rs485)
RS485 serial interface is used.
As soon as GPS tracker polls sensor to get data and sensor replying - Eurosens Display must work in "passive" mode and make only RS485 line monitoring.
What we need:
1. Eurosens Display firmware v1.2 or newer
2. Eurosens Dominator firmware v.2.5 or newer
3. Eurosens Display configuration software v.0.9 or newer
All latest firmware and software you can download from our website www.mechatronics.by
Re: How to connect Eurosens Display RS+Dominator RS+GPS tracker (rs485)
1. Make sensor of the Eurosens Dominator as usual. If you will use several sensors at RS485 line - set then different addresses ("FLS address" parameter)
2. Display settings
Konfig-DisplayRS-3
Konfig-DisplayRS-4
3. Connect all devices together.
You can use either T-cables or direct wiring.
scheme rs rs gps
In the case of direct wiring connect all RS-A wires together, and RS-B wires together too.
