Тема: Axle load sensor Eurosens Difference 01 (Air spring suspension)
Pneumatic axle load sensor is designed to measure the current axle load of a vehicle with air suspension. The sensor can be connected to any AVL unit with an analog (voltage) input.
Parameters
- type of output voltage, V
- supply voltage, V 8-32
-Input pressure, MPa 0-0,8
Thread М16 х 1 ,5
Weight, kg 0,15
Precision
Max error of pressure value measurement 2.5%
Operation conditions
Ambient temperature range,°С from -40 to +80
Output of sensor:
Power supply voltage, V Pressure, KPa Output voltage, V (±115 mV)
24,5±0,5 0 0,205
100 0,635
200 1,087
300 1,542
400 1,99
500 2,432
600 2,910
700 3,367
800 3,817
