1 (изменено: Mechatronica, 2015-02-08 22:52:51)
Тема: Eurosens Delta - most accurate differential flowmeter for engines
Eurosens Delta - high quality rotary piston differential flowmeter. Differential - means it have 2 measuring chambers. You don't need to change fuel feed system.
Eurosens Delta flow sensor DeltaEurosens DeltaDelta PNDelta PN с дисплеем
Advantages:
High-precision measurement
High corrosion resistance
Strong electronic circuit protection
Sealed automobile connector on sensor body
Indication lights provide easy understanding state of device
Modifications:
Eurosens Delta PN 100 flowmeter for max 100 liters/per hour in each channel
Eurosens Delta PN 100 I flowmeter with display for max 100 l/h
Eurosens Delta PN 250 flowmeter for max 250 l/h
Eurosens Delta PN 250 I flowmeter with display for max 250 l/h
Eurosens Delta PN 500 flowmeter for max 500 l/h
Eurosens Delta PN 500 I flowmeter with display for max 500 l/h
Note that maximal fuel flow per channel (chamber) for differential flowmeter does not mean fuel comsumption. For example - fuel consumption of truck can be in 2-60 l/h range, but flow in supply and return line of fuel system at this time 150-300 l/h.
We can help you to choose right flowmeter.
Delta PN - output of sensor is calculated fuel flow in pulses.
Delta RS - sensor with RS232/RS485 interface
Delta CAN - sensor with CAN bus interface
Re: Eurosens Delta - most accurate differential flowmeter for engines
Terex-with-DeltaDelta-on-Terex-Engine
China truck deltaDelta flow meter truck
датчик расхода Deltа на китайском грузовикеEurosens Delta
IMG_2225 Delta тепловоз
Eurosens Delta тепловоз Расходомер Eurosens Delta на тепловозе
3 (изменено: Mechatronica, 2015-01-25 23:51:45)
Operational manual for flowmeters
Firmware for Eurosens Delta flow meters
10.10.2014 version
Now you can order differential fuel flow meters Eurosens Delta RS with RS232/RS485 interface.
Via RS232 or RS485 interface you can obtain not only fuel consumption counter but many other valuable information: time of engine operation, fuel consumption in various modes (idle, overload, normal mode, intervention), time of operation in each mode etc. More information - in Delta RS communication protocol specification.
