Тема: Eurosens Dominator Mini
For installation in restricted areas sensor must be small as possible. New version of Eurosens Dominator casing has small height (22 mm).
Dominator-AF-RS-Mini
Sensors have absolutely same features, connector , wiring and firmware. Sensors are cross-compatible by mounting place and cable.
Only difference : small height of casing and external connector.
Re: Eurosens Dominator Mini
Do you have installed of fuel Eurosens Dominator Mini
3 (изменено: Mechatronica, 2016-11-13 19:10:23)
Of course, why not? smile
it is same sensor as Dominator AF only with low-profile head
Can you give installation of fuel Eurosens Dominator Mini
Absolutely same with
https://forum.mechatronics.by/topic75-e … ation.html
only difference is height of sensor head
