Тема: Eurosens Destination - USB service kit
It is used to connect and configure  sensors of Mechatronics to a PC via USB :
Fuel Level Sensor Eurosens Dominator
fuel flow sensor Eurosens Direct, Delta
Sensors are powered from USB too, no external voltage source is needed.
For data transfer a single-wire interface K-line is used.
Eurosens-Destination-01_200x200
Drivers for Destination 01 service kit are common FTDI drivers with virtual COM-port option.
You can download them in the attachment.
To configure the sensor use the appropriate software (different foe level sensors and flow meters).
Re: Eurosens Destination - USB service kit
Eurosens Destination driver
Eurosens Destination driver (Windows 10, 32-bit)
Eurosens Destination driver (Windows 10, 64-bit)
