Тема: Eurosens Difference onboard weighing + Queclink GV56
Wiring using RS485 interface:
queclink weighing
Re: Eurosens Difference onboard weighing + Queclink GV56
Setting up the Eurosens Difference : According to the Eurosens Difference Installation manual.
Setting up the GPS tracker:
1.    Open RS485 Configuration settings and set type of device : Digital fuel level sensor. Device model no matter – Omnicomm, Escort both will work.
2.     Set number of connected devices to 10
gv56 sensor
3.    Open Serial port setting and set parameters:
Serial port setting
RS485 config setting
4. Report settings
gv56 report settings
Position_1
5.    Add device to Wialon and see data.
Each parameter coming by new address according to the table:
Name of parameter    Which device sends it    Sensor address
Axle load №1    Difference-T  №1    1
Axle load №2    Difference-T  №2    2
Axle load №3    Difference-T  №3    3
Axle load №4    Difference-T  №4    4
Axle load №5    Difference-T  №5    5
Axle load №6    Difference-T  №6    6
Total weight of the truck (tractor)    Display RS    7
Total weight of the trailer    Display RS    8
Cargo weight in the truck(tractor)    Display RS    9
Cargo weight in the trailer    Display RS    10
Now you can assign Wialon sensors to these parameters and use them in reports.
Wialon parametrs
