		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; Free remote tank monitoring software + Eurosens  fuel level sensors]]></title>
		<link>https://forum.mechatronics.by/topic189-free-remote-tank-monitoring-software-eurosens-fuel-level-sensors.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic189.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Free remote tank monitoring software + Eurosens  fuel level sensors».]]></description>
		<lastBuildDate>Fri, 19 Feb 2021 14:16:00 +0000</lastBuildDate>
			<title><![CDATA[Re: Free remote tank monitoring software + Eurosens  fuel level sensors]]></title>
			<link>https://forum.mechatronics.by/post901.html#p901</link>
			<description><![CDATA[<p>Meaning of the Eurosens Tank Manager identifiers:</p><p>&quot;m&quot; - number of message</p><p>&quot;d&quot; - level sensor internal detector value</p><p>&quot;b&quot; -battery level</p><p>&quot;t&quot; - temperature</p><p>&quot;fuel&quot; - fuel value (in liters if tank calibrationtable was programmed in sensor)</p><p>&quot;pv&quot; - percentage of volume</p>]]></description>
			<pubDate>Fri, 19 Feb 2021 14:16:00 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post901.html#p901</guid>
			<link>https://forum.mechatronics.by/post809.html#p809</link>
			<description><![CDATA[<p>We do the same with devices (Devices) and dashboards. After assigning them to the user, you can log in under the created user and see the results.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/52_6802787357.png" alt="52" /></span></p><br /><p>User can only view data but doesn’t have rights to modify dashboards or assets.</p><p>We&#039;ve shown you only the most basic thingsboard features. We recommend that you watch the video on the developer channel and repeat the examples indicated there.</p><p><a href="https://www.youtube.com/watch?v=0io1YnQjIwA">https://www.youtube.com/watch?v=0io1YnQjIwA</a><br /><a href="https://www.youtube.com/watch?v=mqWEGs1Z2BQ">https://www.youtube.com/watch?v=mqWEGs1Z2BQ</a><br /><a href="https://www.youtube.com/watch?v=TyUKx5rNJSs">https://www.youtube.com/watch?v=TyUKx5rNJSs</a></p><p>The system supports embedded programming using Javascript, so you can modify the platform, create your own dashboards and data processing algorithms.</p>]]></description>
			<pubDate>Thu, 27 Aug 2020 15:12:22 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post809.html#p809</guid>
			<link>https://forum.mechatronics.by/post808.html#p808</link>
			<description><![CDATA[<p>Now you need to create user accounts. In the Customers menu, create a customer - a company whose employees will be users of the system.</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/48_2906181714.png" alt="48" /></span></p><p>After creating the company, click on the Manage customer users icon and create a user who will log in to the system as a user.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/49_4755716444.png" alt="49" /></span></p><p>We go through the stage of user activation through a link. Upon completion, we get to the system user screen. There is no access to assets and dashboards yet.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/50_4152566245.png" alt="50" /></span></p><p>We go back as an Administrator (Tenant user) to the Assets section, select the required assets and click the Assign assets to Customer icon. And choose the company.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/51_8015330196.png" alt="51" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 15:09:33 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post808.html#p808</guid>
			<link>https://forum.mechatronics.by/post807.html#p807</link>
			<description><![CDATA[<p>Same widget you can place on the main dashboard (with the map).</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/47_3324839971.png" alt="47" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 15:06:08 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post807.html#p807</guid>
			<link>https://forum.mechatronics.by/post806.html#p806</link>
			<description><![CDATA[<p>The operation of the event detector can be checked by&nbsp; Alarms tab of device properties section. All notifications generated by the workflow will be displayed here.</p><p>Now let&#039;s add this information to the dashboard. Go to the dashboard window and add a widget of the Alarm widget type.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/45_8758645835.png" alt="45" /></span></p><p>In the widget settings, select Alarm source - Entity. And set the alias, describing the objects for notifications - Fuel storages.<br />New tab will appear on the dashboard.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/46_931466156.png" alt="46" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 15:02:17 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post806.html#p806</guid>
			<link>https://forum.mechatronics.by/post805.html#p805</link>
			<description><![CDATA[<p>Now we need to connect the Low fuel chain to the Root rule chain.<br />Having opened the Root rule chain, we see the following default workflow of Thingsboard engine.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/38_6558686597.png" alt="38" /></span></p><p>On the left in the menu, select the Rule chain block and drag it to the algorithm field. We choose a name for the chain - it must match the name of the chain that we want to start. This block is a link to it.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/39_685324808.png" alt="39" /></span></p><p>Next, we connect the output of the Message type Switch to the input of the new block.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/40_3510646652.png" alt="40" /></span></p><p>Select the transmitted data - Post telemetry.It means data from the sensors is transmitted to our chain.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/41_6824854519.png" alt="41" /></span></p><p>The chain is connected. Now, a check for low fuel balance will be launched as a part of Thingsboard workflow, and, if a new warning is present, will launch the chain for sending an email notification.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/42_660076136.png" alt="42" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 15:00:40 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post805.html#p805</guid>
			<link>https://forum.mechatronics.by/post804.html#p804</link>
			<description><![CDATA[<p>It is intuitively clear that the script checks if the volume of fuel in the tank is low. If it is true, an alarm event is generated (Create alarm) and the chain for sending an email notification is started. If the fuel level is OK, then the existing alarm event (if any) is removed.</p><p>If we open the script, we will see that it consists of one line, where the value from the sensors is compared with 10. Thus, the script is triggered if the value from the sensor is &lt;10 and here this value can be changed.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/34_8838847996.png" alt="34" /></span></p><p>The Low fuel email chain called to send an email notification is very simple and consists of two blocks. The first one describes the content of the message and its headers, the second (SendGrid SMTP) specifies the SMTP server settings. The system default settings can be used, which are configured through the Thingsboard system administrator interface.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/35_599582353.png" alt="35" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:57:51 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post804.html#p804</guid>
			<link>https://forum.mechatronics.by/post803.html#p803</link>
			<description><![CDATA[<p>Now let&#039;s set up event handling. We need notification of low fuel level in any tank.<br />Events are defined in the Rule Chains section - rule chains. One of the chains is marked as Root and is the algorithm start point.</p><br /><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/31_6626773718.png" alt="31" /></span></p><p>For more details on the powerful means of defining events in Thingsboard, read the tutorial. We suggest simply importing ready-made Rule Chains. Download Low fuel and low fuel email chains.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/32_2733950526.png" alt="32" /></span></p><p>Open Low fuel rule chain in built-in editor.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/33_7546805348.png" alt="33" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:56:27 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post803.html#p803</guid>
			<link>https://forum.mechatronics.by/post802.html#p802</link>
			<description><![CDATA[<p>Likewise, add the Digital gauge widget to display each of the gauges separately.</p><p>Alias in this case will include a set of one sensor (Tank # 1 and Tank # 2)</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/30_6016048863.png" alt="30" /></span></p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/28_8983827130.png" alt="28" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:50:22 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post802.html#p802</guid>
			<link>https://forum.mechatronics.by/post801.html#p801</link>
			<description><![CDATA[<p>After setting the alias, we specify which parameters to display on the chart. All sensors send the fuel parameter (fuel volume in the tank) and fuel temperature t. We type these parameters, confirming the input of each with the Enter key.</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/26_5677694482.png" alt="26" /></span></p><p>The labels, display of each of the parameters can be changed, as well as the color of the graph.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/27_3239689245.png" alt="27" /></span></p><p>Now we have a fuel volume and temperature plot.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/98_9843268548.png" alt="98" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:46:38 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post801.html#p801</guid>
			<link>https://forum.mechatronics.by/post800.html#p800</link>
			<description><![CDATA[<p>It contains only site pucture from imageurl link</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/99_7550878152.png" alt="99" /></span></p><br /><p>Here we want to see graphs of the volume of fuel in the tanks. Add a new Charts widget, choose Time series and the type of chart you like the most.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/24_863475105.png" alt="24" /></span></p><br /><p>To display the graph, set an alias - all sensor type devices that begin with “Tank”.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/25_3992672087.png" alt="25" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:44:28 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post800.html#p800</guid>
			<link>https://forum.mechatronics.by/post799.html#p799</link>
			<description><![CDATA[<p>We save the changes and see our object on the added widget</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/21_2761632287.png" alt="21" /></span></p><p>Let&#039;s create another one dashboard. We want it to open when clicking on the asset icon on the map. And it will display fuel volume information – actual and historic data.<br />To do this, click on the layers icon at the top left (Manage dashboards states). And create a new state of the dashboard. In the Name field, enter $ {entityName}, in the State id field, create the name of the new dashboard layer - Fuel storage site, i.e. detailed view of the fuel storage area. We do not set the Root state tick - it designates the dashboard layer that is launched by default at startup.</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/22_9373930860.png" alt="22" /></span></p><p>After creating a new dashboard layer, go to the properties of the map widget. In the Actions tab, select the action (Action source), which switches to a new layer - On marker click. We give the action a name - for example, opensite. Select the type of action - navigate to new dashboard state and indicate which dashboard to go to – recently created Fuel storage site. Check the Set entity from widget with the checkbox and save the changes. Now, when you click on the icon on the map, a new widget opens, which is still empty.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/23_3351300037.png" alt="23" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:39:33 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post799.html#p799</guid>
			<link>https://forum.mechatronics.by/post798.html#p798</link>
			<description><![CDATA[<p>Create an alias Fuel storages. It includes all “Fuel site” assets that start with Fuel. The &quot;Resolve as multiple entities&quot; checkbox means that the alias includes multiple assets.</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/18_9908363814.png" alt="18" /></span></p><br /><p>After choosing an alias to display on the map, you need to set the asset parameters: its latitude and longitude. To do this, type the latitude text field and press enter, the same with longitude. </p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/19_7486542435.png" alt="19" /></span></p><p>On the Advanced tab, you can select an icon to display the asset on the map</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/20_6416221060.png" alt="20" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:36:51 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post798.html#p798</guid>
			<link>https://forum.mechatronics.by/post797.html#p797</link>
			<description><![CDATA[<p>Open the dashboard, which does not yet have a single element (widget). Select the Maps widget, the Latest values type - Openstreetmap. Click on it to select. </p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/15_1143887098.png" alt="15" /></span></p><br /><p>You will need to select the data to display on the map. We want to display all our assets on the map. So far, this is one site with fuel tanks, but there will be several of them in the future. This means that the system will have to display all objects. For this, the concept of Alias is used. Let&#039;s create the first alias.</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/17_8375600371.png" alt="17" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:34:51 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post797.html#p797</guid>
			<link>https://forum.mechatronics.by/post796.html#p796</link>
			<description><![CDATA[<p>Now let&#039;s move on to data visualization. We create the “Fuel storage site1” asset - the first site with fuel lubricants tanks. Let&#039;s assign the asset type - Fuel site (probably in the future we will have other types of sites, for example, diesel generators).</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/12_7132251248.png" alt="12" /></span></p><p>Click on the asset and open its properties. Go to the Attributes section and assign field values:<br />latitude, type Double.<br />longitude, type Double<br />Imageurl (http link to image or asset plan) , type String.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/13_5006755995.png" alt="13" /></span></p><p>Now we need to create a dashboard - an operator interface.<br />Go to the Dashboards section and click “+”to add new dashboard. We give it a name.</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/14_4591187057.png" alt="14" /></span></p>]]></description>
			<pubDate>Thu, 27 Aug 2020 14:32:13 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post796.html#p796</guid>
