		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; How to connect Eurosens DPS CAN axle load sensor to GPS tracker]]></title>
		<link>https://forum.mechatronics.by/topic174-how-to-connect-eurosens-dps-can-axle-load-sensor-to-gps-tracker.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic174.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «How to connect Eurosens DPS CAN axle load sensor to GPS tracker».]]></description>
		<lastBuildDate>Thu, 05 Mar 2020 09:22:49 +0000</lastBuildDate>
			<title><![CDATA[Re: How to connect Eurosens DPS CAN axle load sensor to GPS tracker]]></title>
			<link>https://forum.mechatronics.by/post746.html#p746</link>
			<description><![CDATA[<p>Axle load in kilograms in Wialon monitoring:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Wialon_parametrs_and_sensors_values_2093110578.jpg" alt="Wialon parametrs and sensors values" /></span></p>]]></description>
			<pubDate>Thu, 05 Mar 2020 09:22:49 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post746.html#p746</guid>
			<link>https://forum.mechatronics.by/post745.html#p745</link>
			<description><![CDATA[<p>Add sensors in Wialon software:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Wialon_setting_sensor_9461442427.jpg" alt="Wialon setting sensor" /></span></p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Wialon_sensors_6891542058.jpg" alt="Wialon sensors" /></span></p>]]></description>
			<pubDate>Thu, 05 Mar 2020 09:21:12 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post745.html#p745</guid>
			<link>https://forum.mechatronics.by/post744.html#p744</link>
			<description><![CDATA[<p>Same settings for Eurosens DPS connection to Galileosky gps tracker</p><p>Galileo configurator has built-in scanner so we can see Eurosens DPS messages:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Galileo_CAN_Scanner_7249099318.jpg" alt="Galileo CAN Scanner" /></span></p><p>We can see that each message from sensor contains several parameters:<br />bytes 1-2 : internal raw sensor data<br />bytes 3-4 : pressure&nbsp; in kPa<br />bytes 5-6 : axle load in kg</p><p>And we can assign desired parameters to protocol tags column</p><p>Then choose protocol tags to be sent to server<br /><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Galileo_setting_protocol_1629528524.jpg" alt="Galileo setting protocol" /></span></p>]]></description>
			<pubDate>Thu, 05 Mar 2020 08:53:24 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post744.html#p744</guid>
			<link>https://forum.mechatronics.by/post743.html#p743</link>
			<description><![CDATA[<p>Axle load come in kilograms, so calibration coefficients are not needed</p><p>Connection complete</p>]]></description>
			<pubDate>Thu, 05 Mar 2020 08:50:08 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post743.html#p743</guid>
			<link>https://forum.mechatronics.by/post742.html#p742</link>
			<description><![CDATA[<p>Then add 2 sensors in Wialon based on incoming raw data:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/setting_sensor_6617493112.jpg" alt="setting sensor" /></span></p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Wialon_sensors_1619894914.jpg" alt="Wialon sensors" /></span></p>]]></description>
			<pubDate>Thu, 05 Mar 2020 08:41:20 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post742.html#p742</guid>
			<link>https://forum.mechatronics.by/post741.html#p741</link>
			<description><![CDATA[<p>By default - PGNs 59121, 59122, 59123 are used.&nbsp; (E6F1, E6F2, E6F3 in Hex-format)</p><br /><p>Add this PGN to read in GPS tracker settings (Navtelecom Smart 2435 is used), 2 calibration table - for 2 axles per 1 sensor.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/S-2435_CAN_bus_2103429003.jpg" alt="S-2435 CAN bus" /></span></p>]]></description>
			<pubDate>Thu, 05 Mar 2020 08:39:39 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post741.html#p741</guid>
			<title><![CDATA[How to connect Eurosens DPS CAN axle load sensor to GPS tracker]]></title>
			<link>https://forum.mechatronics.by/post740.html#p740</link>
			<description><![CDATA[<p>Eurosens DPS CAN - new axle load sensor from Mechatronics with CAN BUS J1939 interface.</p><p>Each sensor supports up to 3 calibration tables&nbsp; - when we have 3 axles supporting one air spring it is an advantage.<br />Each axle load value can be assigned with PGN.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/DPS_CAN_Config_2050467375.jpg" alt="DPS CAN Config" /></span></p>]]></description>
			<pubDate>Thu, 05 Mar 2020 08:21:18 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post740.html#p740</guid>
