		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; Eurosens Difference onboard weighing + Queclink GV56]]></title>
		<link>https://forum.mechatronics.by/topic168-eurosens-difference-onboard-weighing-queclink-gv56.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic168.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Eurosens Difference onboard weighing + Queclink GV56».]]></description>
		<lastBuildDate>Wed, 18 Sep 2019 09:44:16 +0000</lastBuildDate>
			<title><![CDATA[Re: Eurosens Difference onboard weighing + Queclink GV56]]></title>
			<link>https://forum.mechatronics.by/post702.html#p702</link>
			<description><![CDATA[<p>Now you can assign Wialon sensors to these parameters and use them in reports.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Wialon_parametrs_7742310231.jpg" alt="Wialon parametrs" /></span></p>]]></description>
			<pubDate>Wed, 18 Sep 2019 09:44:16 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post702.html#p702</guid>
			<link>https://forum.mechatronics.by/post701.html#p701</link>
			<description><![CDATA[<p>5.&nbsp; &nbsp; Add device to Wialon and see data.<br />Each parameter coming by new address according to the table:</p><p>Name of parameter&nbsp; &nbsp; Which device sends it&nbsp; &nbsp; Sensor address<br />Axle load №1&nbsp; &nbsp; Difference-T&nbsp; №1&nbsp; &nbsp; 1<br />Axle load №2&nbsp; &nbsp; Difference-T&nbsp; №2&nbsp; &nbsp; 2<br />Axle load №3&nbsp; &nbsp; Difference-T&nbsp; №3&nbsp; &nbsp; 3<br />Axle load №4&nbsp; &nbsp; Difference-T&nbsp; №4&nbsp; &nbsp; 4<br />Axle load №5&nbsp; &nbsp; Difference-T&nbsp; №5&nbsp; &nbsp; 5<br />Axle load №6&nbsp; &nbsp; Difference-T&nbsp; №6&nbsp; &nbsp; 6<br />Total weight of the truck (tractor)&nbsp; &nbsp; Display RS&nbsp; &nbsp; 7<br />Total weight of the trailer&nbsp; &nbsp; Display RS&nbsp; &nbsp; 8<br />Cargo weight in the truck(tractor)&nbsp; &nbsp; Display RS&nbsp; &nbsp; 9<br />Cargo weight in the trailer&nbsp; &nbsp; Display RS&nbsp; &nbsp; 10</p>]]></description>
			<pubDate>Wed, 18 Sep 2019 09:41:29 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post701.html#p701</guid>
			<link>https://forum.mechatronics.by/post700.html#p700</link>
			<description><![CDATA[<p>4. Report settings</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/gv56_report_settings_9807855156.jpg" alt="gv56 report settings" /></span></p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Position_1_1291571259.jpg" alt="Position_1" /></span></p>]]></description>
			<pubDate>Wed, 18 Sep 2019 09:39:35 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post700.html#p700</guid>
			<link>https://forum.mechatronics.by/post699.html#p699</link>
			<description><![CDATA[<p>3.&nbsp; &nbsp; Open Serial port setting and set parameters:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Serial_port_setting_9330575116.jpg" alt="Serial port setting" /></span></p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/RS485_config_setting_3632657234.jpg" alt="RS485 config setting" /></span></p>]]></description>
			<pubDate>Wed, 18 Sep 2019 09:38:28 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post699.html#p699</guid>
			<link>https://forum.mechatronics.by/post698.html#p698</link>
			<description><![CDATA[<p>Setting up the Eurosens Difference : According to the Eurosens Difference Installation manual.<br />Setting up the GPS tracker:<br />1.&nbsp; &nbsp; Open RS485 Configuration settings and set type of device : Digital fuel level sensor. Device model no matter – Omnicomm, Escort both will work.<br />2.&nbsp; &nbsp;&nbsp; Set number of connected devices to 10</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/gv56_sensor_764485229.png" alt="gv56 sensor" /></span></p>]]></description>
			<pubDate>Wed, 18 Sep 2019 09:37:11 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post698.html#p698</guid>
			<title><![CDATA[Eurosens Difference onboard weighing + Queclink GV56]]></title>
			<link>https://forum.mechatronics.by/post697.html#p697</link>
			<description><![CDATA[<p>Wiring using RS485 interface:</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/queclink_weighing_5440660272.png" alt="queclink weighing" /></span></p>]]></description>
			<pubDate>Wed, 18 Sep 2019 09:35:33 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post697.html#p697</guid>
