		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; How to connect fuel level sensor to Teltonika FMB125, FMB630]]></title>
		<link>https://forum.mechatronics.by/topic160-how-to-connect-fuel-level-sensor-to-teltonika-fmb125-fmb630.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic160.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «How to connect fuel level sensor to Teltonika FMB125, FMB630».]]></description>
		<lastBuildDate>Sat, 27 Apr 2019 17:57:45 +0000</lastBuildDate>
			<title><![CDATA[Re: How to connect fuel level sensor to Teltonika FMB125, FMB630]]></title>
			<link>https://forum.mechatronics.by/post648.html#p648</link>
			<description><![CDATA[<p>Setting up the GPS tracking platform (FMB125 and Wialon as an example)<br />Sensor №1&nbsp; – message “io_201”, in 1…4095 range<br />Sensor №2&nbsp; – message “io_203”, in 1…4095 range<br />Create sensor:<br /><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/fmb125_fuel_sensor_wialon_6997572304.png" alt="fmb125 fuel sensor wialon" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 17:57:45 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post648.html#p648</guid>
			<link>https://forum.mechatronics.by/post647.html#p647</link>
			<description><![CDATA[<p>2.&nbsp; &nbsp; Open RS232/RS485 tab and&nbsp; set addresses of connected sensors .</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/fmb_125_sensor_address_3298308798.png" alt="fmb 125 sensor address" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 17:49:12 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post647.html#p647</guid>
			<link>https://forum.mechatronics.by/post646.html#p646</link>
			<description><![CDATA[<p>Setting up the GPS tracker:<br />1.&nbsp; &nbsp; Open I/O section and find LLS fuel level sensors. Set LOW priority and “Event only” option to “NO” for sensors that you will use.<br /><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/fmb125_fuel_level_sensor_settings_4986836132.png" alt="fmb125 fuel level sensor settings" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 17:47:40 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post646.html#p646</guid>
			<link>https://forum.mechatronics.by/post645.html#p645</link>
			<description><![CDATA[<p>Setting up the sensors : set RS485 and set FLS address. Different addresses must be set when you connect several sensors.</p><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/fmb125_fuel_level_sensor_settings_7419869406.png" alt="fmb125 fuel level sensor settings" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 17:44:15 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post645.html#p645</guid>
			<title><![CDATA[How to connect fuel level sensor to Teltonika FMB125, FMB630]]></title>
			<link>https://forum.mechatronics.by/post644.html#p644</link>
			<description><![CDATA[<p>Best solution - to use fuel level sensor with digital interface</p><br /><p>•&nbsp; &nbsp; Interface to be used:&nbsp; RS485 interface<br />•&nbsp; &nbsp; How many sensors can be connected : 5<br />•&nbsp; &nbsp; Wiring (using the Eurosens Dominator RS&nbsp; cable)</p><br /><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/fmb125_rs_wiring_4067345387.png" alt="fmb125 rs wiring" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 17:37:50 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post644.html#p644</guid>
