		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; Eurosens Display unit]]></title>
		<link>https://forum.mechatronics.by/topic16-eurosens-display-unit.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic16.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Eurosens Display unit».]]></description>
		<lastBuildDate>Sun, 18 Dec 2016 17:54:16 +0000</lastBuildDate>
			<title><![CDATA[Re: Eurosens Display unit]]></title>
			<link>https://forum.mechatronics.by/post416.html#p416</link>
			<description><![CDATA[<p>User manual for Eurosens Display configurator</p>]]></description>
			<pubDate>Sun, 18 Dec 2016 17:54:16 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post416.html#p416</guid>
			<link>https://forum.mechatronics.by/post353.html#p353</link>
			<description><![CDATA[<p>Eurosens Display configuration software version 0.4&nbsp; (with update from 29.03.2016)</p>]]></description>
			<pubDate>Wed, 27 Apr 2016 19:53:44 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post353.html#p353</guid>
			<link>https://forum.mechatronics.by/post316.html#p316</link>
			<description><![CDATA[<p><strong>C. Display is working with axle load sensor</strong></p><br /><p>1. Axle load&nbsp; in tonnes<br />2. Pressure (from Destination 01) or angle (from destination 02)<br />3. Output voltage from axle load sensor in volts<br />4. Firmware version</p>]]></description>
			<pubDate>Sun, 14 Feb 2016 11:08:30 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post316.html#p316</guid>
			<link>https://forum.mechatronics.by/post315.html#p315</link>
			<description><![CDATA[<p><strong>B. Display is working with Fuel leven sensor Dominator (up to 10 Dominator sensors are supported) :</strong></p><p>1. Fuel level or Fuel volume*&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; % or liters<br />2. Output signal&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Volts or Hz<br />3. Firmware version</p><p>*to see fuel volume data you need to program tank calibration values in Display table.</p><p>Green LED :&nbsp; Power ON<br />Red LED&nbsp; &nbsp; :&nbsp; &nbsp;Fast blinks : Fuel volume (level) below 10%<br />&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Slow blinks : Calibration table is absent</p>]]></description>
			<pubDate>Sun, 14 Feb 2016 11:05:40 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post315.html#p315</guid>
			<link>https://forum.mechatronics.by/post314.html#p314</link>
			<description><![CDATA[<p>What we can see at Display :</p><p><strong>A. Display is working with Fuel flow meter Direct or Delta (several flow meters are supported) :</strong></p><br /><p>1. Total fuel consumption&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; liters<br />2. Fuel consumption in idle mode&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;liters<br />3. Fuel consumption in nominal mode&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; liters<br />4. Fuel consumption in overload mode&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;liters<br />5. Fuel consumption in intervention mode&nbsp; &nbsp; &nbsp; &nbsp; liters <br />6. Fuel consumption since last power ON&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; liters <br />7. Instant fuel consumption&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;liters per hour<br />8. Total engine operation time&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; hours<br />9. Engine operation time in idle mode&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;hours<br />10. Engine operation time in nominal mode&nbsp; &nbsp; &nbsp; hours<br />11. Engine operation time in overload mode&nbsp; &nbsp; &nbsp; hours<br />12. Engine operation time in &quot;intervention&quot;&nbsp; &nbsp; &nbsp; hours<br />13. Display operation time&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; hours<br />14. Firmware version</p>]]></description>
			<pubDate>Sun, 14 Feb 2016 10:57:02 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post314.html#p314</guid>
			<link>https://forum.mechatronics.by/post209.html#p209</link>
			<description><![CDATA[<p>Eurosens Display configuration software version 0.3&nbsp; (with update from 07.09.2015)</p>]]></description>
			<pubDate>Sat, 26 Sep 2015 11:14:30 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post209.html#p209</guid>
			<link>https://forum.mechatronics.by/post132.html#p132</link>
			<description><![CDATA[<p>Eurosens Display configuration software (with update from 09.04.2015)</p>]]></description>
			<pubDate>Mon, 18 May 2015 19:15:08 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post132.html#p132</guid>
			<link>https://forum.mechatronics.by/post130.html#p130</link>
			<description><![CDATA[<p>Eurosens Display firmware update - version 07.04.2015</p>]]></description>
			<pubDate>Mon, 18 May 2015 18:51:10 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post130.html#p130</guid>
			<title><![CDATA[Eurosens Display unit]]></title>
			<link>https://forum.mechatronics.by/post50.html#p50</link>
			<description><![CDATA[<p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/thumb_Eurosens-Display-F1_900x900_527793243.jpg" alt="Eurosens-Display-F1_900x900" /></span></p><p>Eurosens Display is used to display information from Eurosens fuel flow and level sensors, as well as other manufacturers.<br />You can change settings via special configuration software and Eurosens Destination service USB adapter.</p><p>Connection to other devices with RS232/RS485/K-line interface is also possible.</p><p><strong>Interfaces: RS-232, RS-485, K-Line<br />You can connect several fuel level sensors and(or) fuel flow sensors<br />Customizable<br />Easy mounting<br />Strong circuit electric protection</strong></p><p>For connection you can use standart cables from Mechatronica: </p><p>Connection to differential fuel flow meters Delta:<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Connect_Display_Delta_7197008202.jpg" alt="Connect_Display_Delta" /></span></p><p>Connection to fuel level sensor Eurosens Dominator:<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Connect_Display_Dominator_7794741126.jpg" alt="Connect_Display_Dominator" /></span></p>]]></description>
			<pubDate>Sun, 25 Jan 2015 20:44:16 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post50.html#p50</guid>
