		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; How to connect fuel level sensor  to Teltonika FMB920, FMB202, FMB204]]></title>
		<link>https://forum.mechatronics.by/topic158-how-to-connect-fuel-level-sensor-to-teltonika-fmb920-fmb202-fmb204.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic158.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «How to connect fuel level sensor  to Teltonika FMB920, FMB202, FMB204».]]></description>
		<lastBuildDate>Sat, 27 Apr 2019 16:18:52 +0000</lastBuildDate>
			<title><![CDATA[Re: How to connect fuel level sensor  to Teltonika FMB920, FMB202, FMB204]]></title>
			<link>https://forum.mechatronics.by/post639.html#p639</link>
			<description><![CDATA[<p>Setting up the GPS tracking platform ( Wialon as an example)</p><p>Sensor №1 (AIN1) – message “io_9”, in millivolts</p><p>Calibrate tank according to Eurosens Dominator manual. Lets during tank calibration tank was filled from empty to full condition with 378 liters:<br />1.0 V (1000 millivolts)=0 liters<br />9.5V (9500 millivolts)=378 liters<br />Put these values in the sensor calibration table in Wialon (Generate from XY pairs) and click Generate. You may also limit min and max values in Lower and Upper bound fields.</p><p>Setting is complete.</p>]]></description>
			<pubDate>Sat, 27 Apr 2019 16:18:52 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post639.html#p639</guid>
			<link>https://forum.mechatronics.by/post638.html#p638</link>
			<description><![CDATA[<p>Setting up the GPS tracker:<br />1.&nbsp; &nbsp; Connect sensor and check that analog input can detect the voltage coming from sensor. <br />2.&nbsp; &nbsp; Set LOW priority and “Event only” option to “NO”</p><br /><br /><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/analog_io_FMB920_fuel_sensor_8522278345.png" alt="analog io FMB920 fuel sensor" /></span></p><p>3.&nbsp; &nbsp; To smooth data increase averaging constant to 10.<br /><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/FMB920_fuel_level_sensor_smooth_data_7761268299.png" alt="FMB920 fuel level sensor smooth data" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 16:12:24 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post638.html#p638</guid>
			<link>https://forum.mechatronics.by/post637.html#p637</link>
			<description><![CDATA[<p>Setting up the sensors :&nbsp; switch the Analog&nbsp; output ON (by default it is ON).</p><p>Choose analog output range.&nbsp; For 24V onboard voltage choose 1.0-9.5V, for 12V onboard voltage choose 1-7V.</p><p><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/Fuel_level_sensorsettings__FMB900_8355608452.png" alt="Fuel level sensorsettings&nbsp; FMB900" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 16:07:19 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post637.html#p637</guid>
			<title><![CDATA[How to connect fuel level sensor  to Teltonika FMB920, FMB202, FMB204]]></title>
			<link>https://forum.mechatronics.by/post636.html#p636</link>
			<description><![CDATA[<p>•&nbsp; &nbsp; Interface to be used:&nbsp; Voltage output, connected to the analog input of Teltonika FMB120<br />•&nbsp; &nbsp; How many sensors can be connected : 1 </p><br /><p>Wiring (using the Eurosens Dominator AF 3-wire cable for Eurosens Dominator sensors):</p><p>FMB900 wiring<br /><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/fmb900_wiring_4497279222.png" alt="fmb900 wiring" /></span></p><br /><p>FMB202, FMB204 wiring:<br /><span class="postimg"><img src="http://forum.mechatronics.by/extensions/img_bbcode/uploads/fmb202_wiring_1195808607.png" alt="fmb202 wiring" /></span></p>]]></description>
			<pubDate>Sat, 27 Apr 2019 16:03:34 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post636.html#p636</guid>
