		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; Calibration of the Eurosens Difference onboard weighing system]]></title>
		<link>https://forum.mechatronics.by/topic131-calibration-of-the-eurosens-difference-onboard-weighing-system.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic131.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Calibration of the Eurosens Difference onboard weighing system».]]></description>
		<lastBuildDate>Sat, 10 Mar 2018 07:50:19 +0000</lastBuildDate>
			<title><![CDATA[Re: Calibration of the Eurosens Difference onboard weighing system]]></title>
			<link>https://forum.mechatronics.by/post559.html#p559</link>
			<description><![CDATA[<p>Configurator screens after calibration</p><br /><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_-_calibration_5698661711.png" alt="Onboard weighing system - calibration" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:50:19 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post559.html#p559</guid>
			<link>https://forum.mechatronics.by/post558.html#p558</link>
			<description><![CDATA[<p>Sensor placement and address can be configured with special service software Eurosens Difference configurator.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_-_calibration_1076367958.png" alt="Onboard weighing system - calibration" /></span></p><p>We also need to enter the weight and dimension parameters of the truck and trailer.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_-_calibration_6194053469.png" alt="Onboard weighing system - calibration" /></span></p><p>There are different methods of calibration.</p><p>Calibration with a platform scales<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_-_calibration_712251779.png" alt="Onboard weighing system - calibration" /></span></p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_-_calibration_9988937433.png" alt="Onboard weighing system - calibration" /></span></p><p>Calibration with weights<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_-_calibration_5933252410.png" alt="Onboard weighing system - calibration" /></span></p><p>Each sensor may have its own calibration table.<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_-_calibration_9448858336.png" alt="Onboard weighing system - calibration" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:49:03 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post558.html#p558</guid>
			<link>https://forum.mechatronics.by/post557.html#p557</link>
			<description><![CDATA[<p>The arrangement and number of sensors on the trailer is similar to that of trucks.</p><p>The configuration of a 2-axle trailer requires 4 sensors.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf9_7580458484.png" alt="konf9" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:40:28 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post557.html#p557</guid>
			<link>https://forum.mechatronics.by/post556.html#p556</link>
			<description><![CDATA[<p>A 3-axle truck without a lifting axle requires 4 sensors.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf8_6840250808.png" alt="konf8" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:39:15 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post556.html#p556</guid>
			<link>https://forum.mechatronics.by/post555.html#p555</link>
			<description><![CDATA[<p>Configuration 2-axle tractor and 3-axle semitrailer requires 3 sensors.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf7_8243127255.png" alt="konf7" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:38:02 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post555.html#p555</guid>
			<link>https://forum.mechatronics.by/post554.html#p554</link>
			<description><![CDATA[<p>Configuration 3-axle tractor with 1st lifting axle and 2-axis semi-trailer with 1st lifting axle requires 6 sensors.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf6_5914540062.png" alt="konf6" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:35:10 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post554.html#p554</guid>
			<link>https://forum.mechatronics.by/post553.html#p553</link>
			<description><![CDATA[<p>We determine the minimum number of sensors with the expectation that at least one sensor must be placed on each general axis. The exception is the &quot;tractor + semitrailer&quot; configuration, where no sensor is placed on the front axle. In this case, the load on the front axle is determined based on the load on the tractor&#039;s rear axle, the position of the fifth wheel coupling and the distance between the front and rear axles of the tractor.<br />So, for the configuration of a 3-axle tractor and a 2-axle semitrailer, the minimum number of sensors required for installation is 2 pcs. For a 2-axle truck with a 3-axle trailer, the minimum number of sensors for the installation is 4 pcs. For a 3-axle truck, you can limit yourself to 2 sensors.<br />The minimum number of sensors in the weighing system and the control of the axle load imposes a number of limitations related to the operation of the system. First, the weight of the load and the load along the axes will be correctly displayed if the load in the body is positioned so that its center of gravity is in the middle between the right side of the side of the body and the left. Secondly, in the case of lifting axles, the load on the axle and the weight of the load when one of the axles is raised will not be displayed correctly.<br />Determine the number of lifting axles. Each lifting axle is equipped with at least one sensor. One sensor against two sensors imposes a certain restriction, namely, the position of the center of gravity of the load should be in the middle from the right edge to the left edge of the vehicle.<br />Since the center of gravity of the load (most often) is not located in the middle with respect to the right and left sides of the vehicle, it is recommended to put two sensors per axle. The exception is the rear axle of the tractor, here, setting the sensors on each side is not very important, because the condition of the center of gravity is fulfilled (the fifth wheel is located in the middle) relative to the right and left sides of the tractor. Also, just one sensor is sufficient, if in the air suspension the right pillow and the left have a common line, then there is no sense in placing two sensors on each side.<br /> </p><br /><p>So, the optimal version of the number of sensors for the configuration of a 3-axle tractor + 3-axle semitrailer with the 1st lifting axle is 5 pcs.<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf5_680059092.png" alt="konf5" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:32:48 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post553.html#p553</guid>
			<link>https://forum.mechatronics.by/post552.html#p552</link>
			<description><![CDATA[<p>The method of determining the location and number of sensors consists of the following items:<br />1) It is necessary to determine the number of axles of vehicles. The nearby axes&nbsp; are considered as one general axis. Below are some examples with a different number of general axes.</p><p>With three general axes:<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf1_4093332136.png" alt="konf1" /></span></p><br /><p>With two general axes:<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf2_7622087229.png" alt="konf2" /></span></p><p>With four general axes:<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konf3_7096043019.png" alt="konf3" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:28:11 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post552.html#p552</guid>
			<title><![CDATA[Calibration of the Eurosens Difference onboard weighing system]]></title>
			<link>https://forum.mechatronics.by/post551.html#p551</link>
			<description><![CDATA[<p>Calibration is made with a help of service software Eurosens Difference configurator.</p><p>Eurosens Difference system supports various configurations of lifting axles, pneumatic suspension schemes and trailers.<br />You must choose the configuration in configurator</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/konfiguraciya_avtopoezda_3819056055.png" alt="truck configuration" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:25:05 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post551.html#p551</guid>
