		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; Eurosens Difference  - onboard weighing system for truck and trailers]]></title>
		<link>https://forum.mechatronics.by/topic130-eurosens-difference-onboard-weighing-system-for-truck-and-trailers.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic130.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Eurosens Difference  - onboard weighing system for truck and trailers».]]></description>
		<lastBuildDate>Sat, 10 Mar 2018 07:17:51 +0000</lastBuildDate>
			<title><![CDATA[Re: Eurosens Difference  - onboard weighing system for truck and trailers]]></title>
			<link>https://forum.mechatronics.by/post550.html#p550</link>
			<description><![CDATA[<p><strong>What you need to know:</strong></p><p>■ Each analog sensor is connected via a Difference-T controller<br />■ The protocol of axle load transfer from Difference-T: LLS, each sensor under its own address (0-5).<br />■ If it is not necessary to measure the weight of the cargo (and warning about exceeding the axle load) – Display is not necessary.<br />■ The protocol for transferring cargo weight from Display: LLS (addresses 8-9, tractor and trailer)<br />■ When changing the semitrailer , the system continues to work if the new semitrailer is also equipped with sensors and Difference-T (with calibration). No reconfigurations are required.</p><p><strong>Examples of the Eurosens Difference configurations:</strong></p><p><strong>Load control of dump truck (without trailer), with display and one point of measurement:</strong><br />Eurosens Display RS – 1<br />Eurosens Difference 02 (leaf spring) – 1<br />Mounting set MK Difference 02 – 1<br />Cables.</p><p><strong>Monitoring of axle load and cargo weight of truck with trailer with two points of measurement(first point – truck, second – trailer):</strong><br />Eurosens Display RS – 1<br />Eurosens Difference-T – 2<br />Eurosens Difference 01 (air suspension) – 2<br />Mounting sets MK Difference 02 – 2<br />Cables</p><p><strong>Remote monitoring of axle load (without display) of truck with trailer with two points of measurement(first point – truck, second – trailer):</strong><br />Eurosens Difference-T – 2<br />Eurosens Difference 01 (air suspension) – 2<br />Mouting sets MK Difference 02 – 2<br />Cables</p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:17:51 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post550.html#p550</guid>
			<title><![CDATA[Eurosens Difference  - onboard weighing system for truck and trailers]]></title>
			<link>https://forum.mechatronics.by/post549.html#p549</link>
			<description><![CDATA[<p>Remote axle load control and cargo weight calculation are highly demanded features of the GPS tracking systems. We developed <strong>Eurosens Difference onboard weighing system</strong> which provide features:</p><p>■ Individual axle load measurement for truck and trailer.<br />■ Cargo load calculation.<br />■ Axle overload alarm.<br />■ Show axle load and cargo weight at the driver’s display.<br />■ Transmit axle load and cargo weight values to the GPS tracking system.</p><br /><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_9744860767.png" alt="Onboard weighing system" /></span></p><p>Eurosens Difference system consist from several parts:</p><p><strong>1. Sensors</strong></p><p>Air spring suspension – Eurosens Difference 01<br />Leaf spring suspension – Eurosens Difference 02</p><p>Also you can use any sensors with analog (voltage) output : vehicle sensors, strain gauges, load cells, pressure sensors, etc.</p><p><strong>2. Electronic unit Eurosens Difference-T</strong></p><p>■ Process voltage signal from one load sensor.<br />■ Stores the parameters (dimensions and weight) of truck or trailer (where its installed).<br />■ Stores the calibration data.<br />■ Transmits sensor signal to the digital message in RS485 interface with its address.</p><br /><p><strong>3. Eurosens Display RS</strong></p><p>■ Receives information about axle loads from the Difference-T controllers.<br />■ Determines the weight of the cargo based on the mass-dimensions of the tractor or semitrailer truck.<br />■ Displaying of the axle load and weight of the cargo on the special indicator in the driver’s cab.<br />■ Warning of exceeding the permissible load on one of the axles.<br />■ Output to RS485 interface of cargo weight.</p><p><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Onboard_weighing_system_2913654292.png" alt="Onboard weighing system" /></span></p>]]></description>
			<pubDate>Sat, 10 Mar 2018 07:14:42 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post549.html#p549</guid>
