		<title><![CDATA[Форум для пользователей систем мониторинга автотранспорта &mdash; Temperature stability of the Dominator fuel level sensor]]></title>
		<link>https://forum.mechatronics.by/topic112-temperature-stability-of-the-dominator-fuel-level-sensor.html</link>
		<atom:link href="https://forum.mechatronics.by/feed-rss-topic112.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Temperature stability of the Dominator fuel level sensor».]]></description>
		<lastBuildDate>Thu, 16 Feb 2017 06:57:22 +0000</lastBuildDate>
			<title><![CDATA[Temperature stability of the Dominator fuel level sensor]]></title>
			<link>https://forum.mechatronics.by/post453.html#p453</link>
			<description><![CDATA[<p>We tried to see temperature stability of Eurosens Dominator constant level data during rapid heating from frozed state to hot condition.</p><p>We leave Dominator RS head at deep freeze chamber of the fridge for 18 hours. And then we heated it by industrial dryer.</p><p>At this video you can see how Detector value and temperature value of electronic board are changing during experiment.</p><p>Detector - internal value, not passed from digital processing altorythms.</p><p><div class="fancy_video_tag_player"><iframe class="youtube-player" type="text/html" width="640" height="385" src="https://www.youtube.com/embed/1Jm2Sehicc4" frameborder="0"></iframe></div></p><p>Start detector value (-30 Celsius) at the beginning of the experiment : 3318<br />Maximum detector value during experiment : 3322<br />Minimum detector value during experiment : 3302 (+29 Celsius)<br />After video was stopped the sensor was still connected to PC. And we have a full plot<br /><span class="postimg"><img src="https://forum.mechatronics.by/extensions/img_bbcode/uploads/Dominator_temperatura_3347600875.jpg" alt="Dominator temperature" /></span></p><p>Hot casing still transfer heat to the electronic board at 10 minutes. And last temperature of board : 36 Celsius.<br />But detector values not excess values mentioned above.</p><p>So, maximum change of detector value during experiment (from -30 to +36) is 20 (3322-3302).</p><p>How big this value? <br />For 500 mm sensor, this detector value will change from EMPTY to FULL value approximately by 3000.<br />For 700 mm : 4500<br />For 1000 mm&nbsp; : 6000</p><p>So, temperature error of sensor itself is less than 0.7% (at range from -30 to +36 degrees).</p>]]></description>
			<pubDate>Thu, 16 Feb 2017 06:57:22 +0000</pubDate>
			<guid>https://forum.mechatronics.by/post453.html#p453</guid>
